Door handle seating gasket
Johnluss
Postby Johnluss » 25 Oct 2010 19:45
I am having the door repainted and I have removed the door handle. There was part of a gasket between the body and the handle. Any idea wich material could be used to make one.
Thanks
DNK
Postby DNK » 25 Oct 2010 20:29
Probably anything you want to use from cork, to paper, to a syn rubber of some kind.
Most important is the thickness I would think
Don
"No More Cars For You"
71 TR6- Perpetual remodel
80 TR7 V8 Kick in the pants
seven
Postby seven » 25 Oct 2010 20:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Johnluss</i>
Thanks
You could try some thin rubber sheeting, it can be awkward to cut but a sharp razor blade usually does the trick, and a hole punch for the round bits[:)]
Postby stevie_a » 25 Oct 2010 20:33
<font color="teal"><b>The gasket is shaped plastic
but i see Rimmer as selling it as a paper gasket for £2.20
part No CZK3754</b></font id="teal">
DNK
Postby DNK » 25 Oct 2010 20:42
Also, Brad is showing the part in his data base
Don
Postby TR Tony » 25 Oct 2010 21:19
IIRC the original gasket was the paper type, the plastic ones are repro (& likely to last much longer!).
Postby Chris Turner » 25 Oct 2010 22:59
Robsport sell the plastic gaskets, I think they are Land Rover Discovery parts. Cost about £5
www.triumphtrs.co.uk
THE Coca Cola car
TR7 Premium
TR7V8 rally car
Postby FI Spyder » 26 Oct 2010 01:34
For best results I would cut it from a thin sheet of neoprene which is soft like rubber but chemically resistant. You can buy sheets from you local auto parts store (used as gasket material.) I've got a thicker sheet that i cut my gaskets for the gas tank holes and will use it fot the gas cap seal. Paper doesn't seem too permanent to stand up to car washing and waxing.
elsberry
Postby elsberry » 26 Oct 2010 13:20
The original was paper, as I have one sticking out of a door still that is eventually coming apart for a repaint. Why in the world would they be made of paper though? Last time I checked, paper will absorb water... There has to be some sort of logic to it, I just can't figure out what they were thinking.
Dave Elsberry
1980 US spec DHC
1974 Jaguar SIII XKE
1994 Jaguar XJ12
I need more garage space!
[url="https://docs.google.com/leaf?id=0B26QZc97k0noYTAxMzUxZjgtMzZkZS00MWEwLWEyZmYtOWRkMzliNWZhMDA3&hl=en"]My Triumph Document Repository[/url]
Johnluss
Postby Johnluss » 27 Oct 2010 03:01
Thanks all for the suggestions.
Users browsing this forum: No registered users and 276 guests
