Oil Seals
The Old One
Oil Seals
Postby The Old One » 26 Jul 2010 20:34
Do the 2Ltr heads not have valve stem oil seals?
just removed and stripped the head and there are none.
While i have the head off is there any thing i should
be doing apart from cleaning every thing up and regrinding
the valves.
Postby FI Spyder » 27 Jul 2010 01:58
No oil seals that I know of. Spitfires didn't have them either but a lot of guys used MG oil seals on them. Don't tell me MG's aren't good for anything.[:)]
The Old One
Postby The Old One » 27 Jul 2010 20:43
Thanks for that FI Spyder,any thoughts on mods
while the head is off.
Regards
Postby FI Spyder » 27 Jul 2010 20:56
I would use a quality brand name head gasket rather than a cheapy one. Do a search about retorquing head gasket after a given number of miles. You already have Europe's 9.25 to 1 pistons. If everythings in good nick that's about it unless you want to go to trouble and expense of balance and blue print route. A hotter cam will raise HP to a higher RPM if that's your driving style. But with any engine mod without doing a total package you're only going to get a fraction of a benefit of a piece meal approach.
If you skim the head make sure it's minimal (10 thou or less) or you run into slanted stud to hole issues.
The Old One
Postby The Old One » 28 Jul 2010 20:41
Will take your advice on the gasket (Payen)
and stick with the std cam etc.
Thanks for the advice
regards
Users browsing this forum: No registered users and 186 guests
