The 8 has suddenly developed a large deflection low frequency wheel
wobble at 75 to 82 Km/H, as distinct to the normal high frequency
unbalance shimmy from 95 to 100Km/H. I have never had this wobble
at this speed in any of my 7/8s.
I had the fronts balanced, off car, & this did nothing, or perhaps
made it slightly worse. I watched the balancing, & the wheels ran
true.
We then adjusted one wheel bearing, about a 1/16Th of a turn of the
nut, & adjusted the rack, by removing a 10 thou shim, which
dampened out most of the wobble, but made the rack slightly stiff
from about half lock on the left turn side.
Then replaced the 10 thou shim, & removed a 5 thou, which made the
rack spot on, but allowed a bit more wobble to come back.
I have checked everything in the front end, & found nothing wrong.
The worry is that it has appeared just a day after the bloke who set
up the injection computer had driven the car, without me in the
car, to keep an eye on things.
I will get an on car balance in the next few days, & see what that
does.
