Stag V8 TR7
Hoops
Stag V8 TR7
Postby Hoops » 11 May 2010 10:43
Just out of interest, has anyone put a Stag V8 in a TR7/8? seems an obvious engine to put in to me. [:)]
A halfway house between the sprint 2L 16V and the Rover 3.5L V8?
Postby Beans » 11 May 2010 11:01
And a very heavy option too ...
Bendder
Postby Bendder » 11 May 2010 11:59
A stag with sprint heads and an alloy block. Now, I would put that in! Anyone care to do some casting?
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
Hoops
Postby Hoops » 11 May 2010 12:18
Triumph 32-Valve 3.0L V8, sounds like a plan [:p]
Bendder
Postby Bendder » 11 May 2010 12:28
If someone could actually do it I would put my order in now! It sure would look the part in the car. I like the sound of the Stag and just imagine a 32v short stroke high reving engine. Hummm... I want one. If only I had any machining skills.
1977 TR7 FHC
1978 TR7 FHC
1980 TR7 DHC
1980 Rover SD1 4.0L
Marko
Postby Marko » 11 May 2010 17:56
when you're at the casting why settle with such old head design?
willywonka
Postby willywonka » 11 May 2010 20:57
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Marko</i>
Toyota 20 valve Marko?
All the Gear, no idea
Marko
Postby Marko » 12 May 2010 06:38
yup,
the sickest v8 assembled from other engines ive seen is that hayabusa derived V8 http://www.h1v8.com/page/page/1562069.htm , 400hp , 90kg engine [:D] , price is equally impressive.
engine block is not that difficult to make, heads are the tricky part of the engine
Postby PeterTR7V8 » 12 May 2010 06:58
Sometimes multi-valve V8s are good in theory but other times they really should have done a mock up before committing it to metal. [:0]
John Wood
Postby John Wood » 12 May 2010 13:35
Someone must have tried it, I've seen a dolomite with a Stag V8
1975 FHC
KDU483N
