Boot / Trunk Gas Struts XKC 3893
jazzie
Postby jazzie » 24 Mar 2008 20:44
There is a company in Canada called Strongarm that makes these items. One of the warehouses I call on for my job has a bunch of old boot struts. If you give me the size you are looking for I can search there old stock..
Henk
Postby Henk » 24 Mar 2008 21:21
Here is nobody to refill them so I bougt new ones for 40 euro pp. Found it better then the old stay.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
elsberry
Postby elsberry » 24 Mar 2008 22:08
Ha! First post. Finally found something useful to contribute!
I found replacements at McMaster Carr that fit and worked correctly. I ordered two struts with threaded ends, and stainless eyelet ends to attach them. They are identical to the old struts, bolted right up, and work perfectly. The part numbers were 9416K304 for the struts and 9424K14 for the eyelets. The eyelets were 7.45 each and the struts were 8.61 each. The struts were listed on my order as - Gas Spring with Threaded Ends 70 Force, 5.90" Extended Length, 2.36" Stroke
Hope that helps - No affiliation with them, just found some that work really well.
Dave
1980 Poseidon Green DHC - Being restored
Postby tr7inc » 25 Mar 2008 13:35
Hi Odd just out of curiosty what hold that bottom bracket to the car? is it welded the the car itself?
Many thanks
Postby Odd » 25 Mar 2008 14:21
Originally it was spot welded in place. Three spots istr...
If you're rebuilding a shell - plug weld it in place.
If you are (like me) 'after paint' - rivets or screws/nuts. (I'm aiming for countersunk screws and nuts myself.)
Postby tr7inc » 25 Mar 2008 19:22
Odd yes i have to admit i thought it was spot welded, has thought about getting the old poxy reasin out instead...... only joking bet someone out there has though i'll bet!
Postby Underdog » 25 Mar 2008 21:40
That's good to know. I have new ones purchased from Rimmer several years ago. I'm going to print out those #s & stick it in the shop manual just in case.
Postby Hasbeen » 25 Mar 2008 21:46
The worst rust I have seen on a 7, is on the boot prop on my spares
car.
It is still attached to the boot lid, but is hanging down from there,
with a rusty bit of the rain gutter still welded to its bracket. At
the rain gutter is a large rust hole, so do not take this job
lightly. The rain gutter is still wet, long after most of the car is
dry, & the action of the prop, continually flexes the gutter,
cracking the paint, in the area.
Postby Odd » 25 Mar 2008 22:27
Good point, about the flexing. I'll have to start thinking.....
mb4tim
Postby mb4tim » 26 Mar 2008 00:25
I've already logged into McMaster.com and bookmarked these parts! I'll bury them in my next order.
What "force" did you get? 15-80 pounds are available.
Thanks for the great info!!!
-Tim
elsberry
Postby elsberry » 26 Mar 2008 01:56
Tim,
They are 70 lb force struts. They come threaded with no ends, and I purchased two of the stainless steel ends for each strut. They are a bit high for four of the ends, but I picked those based on the length of the ends combined with the struts, and the size of the eyelet. They slipped in without issues using the original bolts.
I'll see if I can get a picture of them installed for you tomorrow during the day, and get it posted.
Dave
grndsm
Postby grndsm » 26 Mar 2008 12:34
Good find, Dave!
I use McMaster almost daily for my "day work", but for some odd reason, I rarely think of it for my car work [:I]. This is definitely a case where it work very well!
But what is more, I want to design a gas cylinder application for the hood (bonnet) and this should give me a lot more choices than what I was going to do (sort through a bunch of other cars gas struts).
Leon
'80 TR7 Spyder GS-T <undergoing Mitsu 4G63T transplant
Postby bmcecosse » 26 Mar 2008 18:41
SGS in Uk offer a re-gassing service, and new struts of every size! http://www.sgs-engineering.com/gas-struts/re-gas.php
pbee
Postby pbee » 29 Mar 2008 15:01
thank you, there are plenty of options to try out
dave.c
Postby dave.c » 29 Mar 2008 15:58
Hi all
I'm also interested in new struts tried to read numbers on mine but a bit worn so not sure if correct or not can anyone confirm the pressure so I can get some made up
i'm assuming its 350 NewtonsImage
sent an e-mail to SGS but no reply
ATB Dave
