I know they tend to be on the 7 but, having finally fitted a working gauge last summer, I now find on starting after the winter layup that it registers but also very slowly cycles up and down continuously about 1/8 to 1/4 of a tank about the 1/4 full point (which I assume is the current tank contents).
Over the winter I have had the dash out to fit LED backlight bulbs and cleaned all the contacts. I have also fitted a 'new' alternator which gives a much better charge (just in case any of this is relevant). Can it be the voltage regulator (is this the small 'block' bracketed to the instrument perspex cover screw?), or are there any other ideas?
Saab 9000 Stg 1
