Rear fog lights
welshsteve
Rear fog lights
Postby welshsteve » 07 Feb 2008 18:07
My TR is due it's mot[:(] and I just found out the rear fogs don't work[xx(] any advice on how to get them working is greatly appreciated[;)]
Cheers Steve
If it's got tits or tyres then it's gonna cost ya!
Steve @ SandS
Postby Steve @ SandS » 07 Feb 2008 18:40
Your not checking them with main beam are you ??
Steve @ S&S Preparations
welshsteve
Postby welshsteve » 07 Feb 2008 18:56
No Steve they don't work on main head lights or main beam
Cheers Steve
Steve @ SandS
Postby Steve @ SandS » 07 Feb 2008 19:01
They shouldn't work when main beam is on.Check that power is getting to the lights when the switch is operated.If it is it will probably be the connections inside the light units, more than likely bad earths.
welshsteve
Postby welshsteve » 07 Feb 2008 19:03
Thanks Steve I appreciate it mate
Cheers Steve
Postby john 215 » 07 Feb 2008 21:11
Hi Steve,
Just a thought, if your car was registerd BEFORE April 1st 1980 then you do not need them for an MOT test. If after that date only need an O/S OR centre rear fog lamp. Hope this helps,
Cheers John.
welshsteve
Postby welshsteve » 07 Feb 2008 21:15
SEPT 80 Gutted
Thanks though John
Cheers Steve
Postby john 215 » 07 Feb 2008 21:20
Hi Steve,
DOH [V] well at least if you have to, you swap the N/S to the O/S or use the bits out of one to get it working.They seam very prone to corroding inside.
Cheers John.
welshsteve
Postby welshsteve » 08 Feb 2008 18:29
Just dirty connections but thanks for the help guys , on the plus side the car went through with no other problems[:D] thats a real weight off my mind[;)]
Cheers Steve
Postby bmcecosse » 08 Feb 2008 21:49
Well done ! Roll on the good weather.
Users browsing this forum: No registered users and 261 guests
