Turn Signals don't work
striker308
Postby striker308 » 15 Oct 2007 23:56
I've had my '76 TR7 for only a week now and upon inspection of things not working I discovered that it didn't even have a turn signal switch/relay. The new one arrived today and I plugged it in and nothing!!!
What are the common reasons the turn signals don't work? I know bulbs!! Anyone have some experiences to share?
Thanks,
Karl
1976 TR7
1982 VW Scirocco
Postby FI Spyder » 16 Oct 2007 01:16
Most common problem is a corroded hazard switch as the turn sgnal goes through it. If it's corroded the electricity can't go through, no signal. Take hazard switch apart and clean. It has copper contacts so they corrode easily. Put some dielectric grease on them after cleaning to keep them from re corroding.
mb4tim
Postby mb4tim » 16 Oct 2007 02:12
^^^^^^^^^^^^^ ditto! ^^^^^^^^^
Cleaning the switch worked for me!
-Tim
Postby jclay (RIP 2018) » 16 Oct 2007 11:51
Do your wipers work?
Wiper, brake lights and turn signals are all one one fuse, #15/16, 25 amp.
striker308
Postby striker308 » 16 Oct 2007 14:40
I did clean the hazard switch and the hazards work. I do have working wipers. I did order a new turn signal control since the current one seems broken with the high beam control. If I'm not careful and bump it the high beams come on............and drain the battery.
Jclay, I did find an old post of yours about the turn signal wiring. I guess it's just one of the joys of ownership!!
Karl
1976 TR7
1982 VW Scirocco
Postby FI Spyder » 16 Oct 2007 19:57
It might be the turn signal control. I had replaced mine first because of broken high beam control. As turn signals still didn't work I went to hazard switch which did. Your case might be the reverse.
striker308
Postby striker308 » 16 Oct 2007 23:44
Thanks for all the suggestions. Hopefully, my new turn signal control will be here in a few days.
Karl
1976 TR7
1982 VW Scirocco
striker308
Postby striker308 » 21 Oct 2007 00:59
Update: I now have turn signals!!!!!! I purchased a new turn signal switch. The one around the steering wheel. However, they only flash for about 5-10 seconds and then they stop flashing.
Bad fuse??
Karl
1976 TR7
1982 VW Scirocco
Postby jclay (RIP 2018) » 21 Oct 2007 01:51
Maybe the flasher unit is overheating!
striker308
Postby striker308 » 21 Oct 2007 01:55
If it is, what should I do??
Karl
1976 TR7
1982 VW Scirocco
Postby Odd » 21 Oct 2007 03:31
Get an electronic flasher relay.
striker308
Postby striker308 » 23 Oct 2007 00:48
Turn signals work fairly well. Now, I need to work on the running lights. Any suggestions?
Karl
1976 TR7
1982 VW Scirocco
Postby Rich in Vancouver » 23 Oct 2007 01:33
Clean and check all connections.
Bad grounds are a common problem.
Richard
Users browsing this forum: Google [Bot] and 67 guests
