I'm just about to put my engine back together and in the process of cleaning out the waterways - how clean do they have to be ?
I've been using scrapers, screwdrivers and boiler flue wire brushes to loosen the scale and a variety of suction tools made from flattened copper tube and connected to my Henry Vac - would this be enough ?
Also, would there be any benefit in removing the large plug on the side of the block ? I guess the smaller plug is the coolant drain but what is the function of the larger plug above it ?
