TR7 Cruise / Marker Lights and Covers TR8
Spectatohead
Postby Spectatohead » 11 Aug 2015 05:13
supercass wrote:I think in the USA they are known as side marker lights. supercass
Right you are. A descriptive but unimaginative term I'll admit. I like the "cruise lights" term.
Jim Clark
'80 TR8
'06 G35 Sedan 6MT
Re: Cruise Light fitting
Postby john 215 » 11 Aug 2015 07:23
I did notice these cruise lights at TR Reg IWE on a Irish TR7 V8, didn't see them lit up but something different !
TR7 Rear Cruise Light
Postby UKPhilTR7 » 10 Apr 2020 11:53
On my car I have the rear cruise lights. They are on when the lights are on.
I was wondering if anyone has wired them up to flash when the indicators are on too, or would that not be allowed on the roads as the flasher needs to be amber?
Postby Cobber » 10 Apr 2020 13:13
Do what I've done.......I've used amber front ones in the rear
'80 Triumph TR7.
'98 MG-F.
'83 Jaguar XJ6 Sovereign S3.
Re: Rear Cruise Light
Postby UKPhilTR7 » 10 Apr 2020 14:30
Thinking that too mate, use amber ones. So that when you indicate they flash and when you are driving they are on all the time, driving cruse lights.
Postby Beans » 10 Apr 2020 19:03
Did the same as Cobber. Feed is taken from the closest original indicator. So they indicate only
Postby stevie_a » 10 Apr 2020 20:38
Putting them as a cruise light and an indicator is more bother than it is worth.
If you wire it up to side lights and then indicate, when the back light goes on the cruise light will go out they don't flash in the same sequence.
I think you need to put a relay on each light for it to work sequence
sonscar
Postby sonscar » 11 Apr 2020 16:47
I wired my fronts as sidelights and also to flash and indeed they do alternate their flash but it does not cause me to worry,Steve..
supercass
Postby supercass » 14 Apr 2020 23:21
I believe indicators not flashing simultaneously is an MOT fail. I also understand the vehicle lighting regs only allow for one repeater.
supercass
Postby Cobber » 15 Apr 2020 07:57
supercass wrote:I believe indicators not flashing simultaneously is an MOT fail. I also understand the vehicle lighting regs only allow for one repeater.
supercass
This would depend on the juristiction.
Here in Victoria Australia, there is no limit on the number of repeaters but they must be Amber, where as red cruise lights would probably be a technical fail ( most coppers wouldn't bother, but a nasty bastard would book you for it)
'80 Triumph TR7.
'98 MG-F.
sonscar
Re: TR7 Rear Cruise Light
Postby sonscar » 15 Apr 2020 19:24
Only the fronts flash and Mot has been no problem and you can only see the side or the front but not together.Steve..
Postby busheytrader » 20 Apr 2020 18:30
I had a look at this website. I definitely need to get out more........
http://www.legislation.gov.uk/uksi/1989 ... ule/7/made
as I wondered if you could have amber rear cruise lights that flash with the rear indicators.
I have flashing amber at the front - I reckon they're a must have.
I have red at the back that light up with the side lights.
Flashing red is a fail as "direction indicators" must be amber after 1/9/65 it looks like flashing amber isn't ok at the rear.
http://www.legislation.gov.uk/uksi/1989 ... 796_en_001
I'd expect that since I can't recall any cars having flashing rear "side direction indicators" that it isn't.
Postby UKPhilTR7 » 21 Apr 2020 20:24
I have the feeling that this may be a lot more trouble than it is worth :D
Users browsing this forum: No registered users and 157 guests
