Gearbox mounting.
carlton
Gearbox mounting.
Postby carlton » 10 Sep 2017 17:27
Hi all.
Anyone got a photo of the gearbox mount in situ. I can't quite figure out why so much of the mount appears to be below the hole in the mounting cross member and wonder if it has dropped as I understand these mounts are prone to do.
Thanks.
Monkeyzak
Re: Gearbox mounting.
Postby Monkeyzak » 10 Sep 2017 17:32
I had the same problem. Have a look at the Rimmer's parts drawing online. I had a part in the wrong place. It shows how it should go back together
seven
Postby seven » 10 Sep 2017 17:52
Probably not the best condition gearbox mount, but in situ
DSC01470 (Small).JPG (64.46 KiB) Viewed 6127 times
Dodge Dakota 4x4 '05
Triumph TR7 DHC '81
Triumph 2.5 Estate '73
Triumph 2.5PI Saloon '69
Triumph Herald 12/50 '65
Mercedes SLK250 '14
Mercedes SL55 AMG '02
Mercedes E320 '05
Mitsubishi Canter '01
Rolls Royce Silver Shadow '76
Volvo 262c '78
Fiat Ducato Motorhome '03
Kawasaki GPZ '93
Kawasaki GPZ '92
Postby Beans » 10 Sep 2017 23:18
Viewed from the back on a car that was restored some 7 years ago;
carlton
Postby carlton » 11 Sep 2017 01:31
Thanks for that. I guess then that when it drops the lowest metal part shown in the photo stays in the same place and the rubber element perishes, breaks away and slides over it??
seven
Postby seven » 11 Sep 2017 11:14
carlton wrote:Thanks for that. I guess then that when it drops the lowest metal part shown in the photo stays in the same place and the rubber element perishes, breaks away and slides over it??
Certainly looks that way, I guessing the rear of the gearbox drops to as the mount slow melts and oozes eeewwwww :shock:
Triumph TR7 DHC '81
Mercedes SLK250 '14
Mercedes E320 '05
Volvo 262c '78
Kawasaki GPZ '93
Kawasaki GPZ '92
Postby Beans » 11 Sep 2017 15:27
On top (between rubber mount and distance piece) sits a movement restriction plate.
This should prevent the box from dropping to much when the rubber tears out.
carlton
Postby carlton » 11 Sep 2017 22:42
Hi. Sorry about all the questions! Why is so much of the mount evident below the mounting plate where to my (no doubt ill informed mind) it seems to serve no useful purpose? Would it be evident viewing the mount from the back of the car that the gearbox mounting has dropped or do I need to view the top of the mounting cross member? Is it common for the mount to fail and the gearbox to drop sufficiently to damage or fracture the exhaust or manifold? The mounting is over 30 years old so I guess it is probably knackered. Thanks.
Postby saabfast » 12 Sep 2017 12:27
As above, the mounting cannot drop a lot due to the arrangement with the plate above. If the rubber gets that soggy or fails it will just transmit more noise and vibration to the crossmember as it will have direct metal to metal contact. The bigger problem in a way is failure of the rubber mounts on the extension above the tailshaft which can let the extension drop down onto the prop UJ/CV joint.
Users browsing this forum: No registered users and 279 guests
