alc59 wrote:Like this a lot. So what did you buy and who from?
Al
So far I have got all my LED’s from ebay, with the most popular point of origin being China or Hong Kong. It did make me laugh though when I was looking for them. The first page would show all the local sellers (one even down the road) and the cost of p&p was anywhere from $2 to $10+. However, on the second page I could get the same items from China for free p&p. Guess which ones I went for lol. I have a list
Below is a list of all the standard bulbs and their led equivalent that I have put together. This was only designed for my own use, but if it can help others, I am more than happy to share it. I can confirm all of the bulbs in the interior section are correct and work just fine. I can also confirm that the front side lights, the number plate and the rear side running bulbs are correct. However, as yet I have not replaced the rear light cluster lights, so cannot confirm they are correct. However, I am pretty sure they are.
The links below are to the bulbs that I brought. These links are only for reference (the pictures & type). However, I can confirm that they work all OK for me and my dash:
Dash illumination strip:
http://www.ebay.com/itm/141805574486?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITDash Heater Console:
http://www.ebay.com/itm/291708453216?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITDashboard Background Lights:
http://www.ebay.com/itm/160982226419?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITmanny wrote:are we seeing them bleed into the indicator..err...indicators
Not too sure if you mean the first picture that I posted, however I will answer it as if you did. Nope no indicators being beamed/bleed into the cockpit, this is the original light on the right with the new led on the left, with the switch panel down. When I was fitting them, I just wanted to check the difference between the two bulb types and to also confirm if I had made the right decision to change the entire interior to led, which I now believe I have. The second set of pictures show the led’s in the switch panel all fitted and looking great.
