Has anyone refitted the two curved rails that the hood/top attaches to on the rear quarter deck of a convertible.
I am building up a stripped shell and have got to this stage. The problem seems to be that the correct sized rivets don't actually go through the hood stud base, the outer part of the rail and the body flange sufficiently for the rivet to get a good purchase on the body flange.
I can get one or two to work but the rest not. The problem seems to be that the rivet comes up against the inside face of the curved rail and that stops it seating completely. I don't want to drill right through the rail (both inner and outer faces) and use a longer rivet as that will leave an unsightly line of fixings visible inside the car.
Obviously Triumph didn't have this problem when they vehicle was manufactured but I fail to see how they did it. I am using the correct sized rivets, a rather short bodied version because of the restricted space.
Any help would be very gratefully received as I am currently stuck on this particular aspect of the rebuild (mind you, plenty still to keep me busy so it isn't holding up progress just yet).
