Postby Stag76 » 10 Sep 2016 23:52
The problem with the TR7 braking is not down to the booster, but the size of the front discs.
Brakes operate by turning kinetic energy into heat, and as the discs get hotter, the ability
to convert to heat is reduced until it reaches the "Brake Fade" stage. There is not enough surface
area or volume to dissipate the heat generated in the 9mm solid discs.
A bigger booster will increase the clamping pressure, which will improve the braking, but,
at the same time, heat the discs up quicker, so fade will happen sooner. Different combinations of
pads etc. have the same effect.
The existing booster is capable of servicing a lot bigger discs and calipers, up to the stage where
it cannot supply the fluid transfer required. Rodney Wells on this forum used the standard booster
with holden 2-pot calipers and Subaru WRX discs to good effect on his 4.0 litre Toyota powered TR7.
The only real solution is to increase the size of the front discs, pads and calipers.
