kstrutt1 wrote:
Feed from the manifold goes to the bottom, return to the water pump inlet goes to the top. this works very well on mine.
If you are having other random cooling issues check the de-gas line on top of the manifold, the little cover held on with 3 screws has tiny bled hole which blocks up, you then get an airlock behind the thermostat delaying i't opening.
alc59 wrote:I have an earlier SD1 manfold which doesn't have the hole and cover. Do you also vent from the pipe at the top of the carb pedestal?
Al
Users browsing this forum: No registered users and 239 guests
