Siezed Tie rod bolt
g4zur
Siezed Tie rod bolt
Postby g4zur » 16 Nov 2015 19:34
Hi All
The bolt securing the nearside tie rod to the subframe spins easily nut off. But for some reason can't get the bolt out.
Could someone please help.
Many thanks as always.
Gareth.
G.P.Albrighton
sonscar
Re: Siezed Tie rod bolt
Postby sonscar » 16 Nov 2015 19:42
sounds like the bolt has rusted into the metal bush in the rubber outer.Hacksaw blade carefully and patiently wielded is on the cards I fear.Steve..
DNK
Postby DNK » 16 Nov 2015 19:43
Does the tie rod attach to the Sub?
Don
Stick a Wedge In It
80 TR7 V8 Kick in the pants
Postby FI Spyder » 16 Nov 2015 20:26
I'm guessing he means steering rack to subframe. If that is the case, typically the way to remove a rust bolt (that isn't screwed into threads) is to put on nut in till it sits just past the bolt (maximum threads contacting without exposing bottom of bolt) and tap with a hammer until it is free. Wear your ear protection as always.
Users browsing this forum: Google [Bot] and 311 guests
