Hi
Does anyone have pictures or advice as to how to fit a stabilizer bar (similar to the one on a dolomite) to the top of a sprint engine with an S&S sports exhaust manifold in a TR7 please.
Any help would be gratefully received.
Thanks
Allan
dursleyman wrote:My exhaust manifold is a stainless one from S&S and yes there is not much clearance to the chassis rail so I did the same mod to my engine mounts which leans the engine over slightly and that seems to be enough to prevent serious contact. Actual clearance is about 1/4". I am also using some old soft engine and gearbox mountings rather than the modern harder replacements because it reduces vibration and noise. There is a small mark showing that there must have been contact sometimes but its not enough for me to worry about. If I was using the car for any kind of competition work then the hard mountings would go back on.
I understand some folks "modify" the manifold and/or the chassis rail with a hammer to achieve the same result but that seems a bit too crude for me.
