Postby FI Spyder » 08 Jun 2015 15:08
Just because the connectors are clean doesn't mean the wiring is good. Wires can break inside the insulation which is difficult/impossible to see because the connector case is covering it or the insulation itself. You can do some voltage measurements (power on) or continuity measurements (power off, battery disconnected to be safe). I had that happen to me not on fuel gauge circuit but had no instrument lights. Turned out a broken wire where it went into a connector after the dash light dimmer. Difficult to see, easy/cheap to fix. This can happen at any connector in the car.
