Peter Nuss wrote:Both types are as original, depending on the year of your car. The flat plate was used on cars from 1979 down. The paint can type were used later. 1980 on up.
Both types were sealed with seam sealer. The flat plate one is sealed better as the sealing surface is larger, the plate is stronger and fits nicer. I remember when the paint can style was first reproduced, because they rotted away so quick.
To answer your question. The paint can ones push in, the flat plate ones just sit in the in the floor. Both are sealed with seam sealer, not silicone. Paint will not adhere to silicone, but will to seam sealer. And yes, you can make your own if you can cut a circle.
Users browsing this forum: No registered users and 318 guests
