Shims using MGF Wheels
bonnietiler
Postby bonnietiler » 24 Feb 2014 09:05
Would I need to add shims if using MGF wheels?
By using my stick my hand up the wheel arch digitally corrected imperial atomic clock-accurate method, it seems like they are a little narrower in track?
Brian
Stag76
Postby Stag76 » 24 Feb 2014 09:23
I don't use them.
TR7 Convertible
Sprint Motor
MegaSquirt EFI
HowardB
Postby HowardB » 24 Feb 2014 09:34
I don't either (MGF 14") and car has covered about 20k since I fitted them without any problems
Ianftr8
Postby Ianftr8 » 24 Feb 2014 11:25
I don't either although I had to just wet & dry the mounting on the front wheels so they fitted the hubs (just to remove a few thou).
Ian
Ian Freeman
1979 TR8 DHC KDU 315V Poseidon Green
Triumph Courier
Triumph owner for 32 years
Postby TR Tony » 24 Feb 2014 14:13
I had MGF 15" wheels on my old TR7V8 DHC, fitted no problem, no shims or spacers required. I think the offset is different but it didn't cause a problem.
Users browsing this forum: No registered users and 362 guests
