Suspension Wrench Torque
kermit
Postby kermit » 26 Oct 2011 13:15
I am in the process of sorting out a broken down ball joint and worn shift bushings. What do people recommend for the wrench torque settings for the following:
1. Ball joint castle nut
2. Control arm (link) nut at hinge point bolt
3. Front sway bar end nut at control arm
4. Upper & lower shift bushing bolts
80 TR7 DHC with ZS Carbs
Brooklands Green
Postby Beans » 26 Oct 2011 18:01
I'd recommend the work shop manual settings.
You can down load a pdf from jclay's site
kermit
Postby kermit » 27 Oct 2011 10:47
Beans, thanks for the recommendation of jclays website. There is a wealth of good information there.
Brooklands Green
Users browsing this forum: Google [Bot] and 272 guests
