Fitting an immobilizer.
Bobbieslandy
Postby Bobbieslandy » 08 Feb 2015 10:42
You can buy a remote key fob operated switch. Fit this inline with either the leccy fuel pump if you have one or the ign circuit with careful consideration to cable routing to avoid someone bypassing it too easily. The good thing about this is you can have it tucked away and / or boxed in under the car so it's invisible and inaccessible without tools.
Postby saabfast » 08 Feb 2015 11:51
My car has a hidden switch in the cable from the ignition switch. Trouble is, I only use it occasionally, then get back in and curse because it won't start until I remember to switch back on. Memory failing with age[:(].
kstrutt1
Postby kstrutt1 » 08 Feb 2015 18:37
I used a hrw switch fitted to my drophead which switches the low current side of the fuel pump (v8 electric) unfortunately the only time it has broken down is when the switch failed!
Postby Cobber » 08 Feb 2015 20:19
Who needs an immobililizer when we have Lucas electrics? [:D]
'98 MG-F, 69'Ford F250.
manny
Postby manny » 09 Feb 2015 12:57
Hi all,
I intend taking this route..
http://www.autospeed.com/cms/article.html?&A=112952
may be along with my additional fuel pump switch..
Manny
TR7 V8 1982
Reliant Scimitar GTE 6a 78
Kawasaki ZX636R
Piaggio fly 125
RIP Stick 2013
Postby dursleyman » 09 Feb 2015 13:18
Manny, that gadget in your link is on Ebay for £2.99 plus £2.39 postage. Must be worth a go.
http://www.ebay.co.uk/itm/12V-Multi-fun ... 3f0c62466f
1981 TR7 Sprint DHC
manny
Postby manny » 10 Feb 2015 05:53
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dursleyman</i>
Russ <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
yes , it does seem a good way of immobilizing the car without too much intrusion - on the Scimitar i am looking at a RFID ignition switch - using an ardunio
Manny..
TR7 V8 1982
Kawasaki ZX636R
Piaggio fly 125
RIP Stick 2013
Postby gaz » 10 Feb 2015 14:32
simple, fail safe and if you loose the red key most motor factors, garages, even halfords will have a spare for you:
1981 DHC 2.0 Litre
1980 DHC pedal car
Dave Dyer
Postby Dave Dyer » 10 Feb 2015 19:21
Hi Chaps,
I've just finished replacing the engine bay wiring and can see its way too easy for a thief to start a standard (mechanical fuel pump) TR7.
You can put your starter motor or ignition feed through hidden switches, but all thats needed is to connect a wire from battery positive to the + side of the coil (ignition) and another to the starter solenoid on the starter motor.
And thats it! simples (unfortunately)
And if you use a battery isolator, the thief can do the above, but also connect a jump lead from battery to starter motor.
An electric fuel pump would be harder to get around if isolated via a hidden switch, but not everyone has an electric one.
There is the mechanical option, locking the gearstick or around the steering wheel etc.
But the best thing would be a sensor on the drivers seat, so if a thief sits down (without operating the secret switch) he gets a spike up his jacksie!
Cheers, Dave
Postby saabfast » 10 Feb 2015 20:16
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave Dyer</i>
Hi Chaps,
..and you get a ventilated seat (albeit with a few stains).
I use a Stoplock through the steering wheel as a visible deterrent. Don't know how good they are but I did know a guy who used one in the station car park years ago. Idiots sawed through the steering wheel, bent a bit back and slipped it off to pinch it - and it was only a Mk 1 Fiesta worth a few hundred at the time!
Postby dursleyman » 10 Feb 2015 20:30
Let's face it, if someone really wants to steal the car they will, but all of our methods will deter the casual scumbag.
1981 TR7 Sprint DHC
Postby Cobber » 11 Feb 2015 02:55
But the best thing would be a sensor on the drivers seat, so if a thief sits down (without operating the secret switch) he gets a spike up his jacksie!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
There are some troubled souls out there who would see that as an incentive, rather than a deterrent! [:D]
