Felt replacement
vitessesteve
Felt replacement
Postby vitessesteve » 15 Jan 2015 15:02
What are your thoughts on using a Dynamat type product in place of the underfelt. I have stripped out the interior to get things properly dry over the winter rest. The felt really holds any water that gets in so my thoughts are that something less absorbent would be better. Less likely to soak up water and get smelly.
Steve Weblin - AKA vitessesteve
1982 TR7 Sprint DHC
Postby Workshop Help » 15 Jan 2015 15:33
Yes! Do it!
sonscar
Postby sonscar » 15 Jan 2015 19:32
Being a total cheapskate and based on experience from ny son's classic Mini I used self adhesive roof flashing band on the floor and bulkhead.Easy if slightly messy to fit using a hairdryer,sticks like the proverbial to a blanket and I hope the bitumen backing affords some waterproofing.Steve..
]Image
mine
Postby Beans » 15 Jan 2015 19:57
What do you mean with "underfelt"?
Never seen anything other than a bitumen mastic kind of anti resonance material on a TR7.
On the DHC I removed everything and replaced it with this product from 3M ...
Lighter and better sound proofing compared to the original material.
<font color="blue"><i>1976 TR7 FHC (currently being restored ...)
</font id="blue"><b>[url="http://www.tr7beans.blogspot.com/"]<u><b><font size="2"><font color="red">Click this link for a full version of this blog</font id="red"></font id="size2"></b></u>[/url]</b></i></center>
vitessesteve
Postby vitessesteve » 16 Jan 2015 07:48
My car has carpet felt underlay stuck to the floor and sills. Will post a photo later.
Image[/URL]
1982 TR7 Sprint DHC
sonscar
Postby sonscar » 16 Jan 2015 10:25
Looks like the flashing band I mentioned in the rear floor.Steve..
]Image
mine
Image[/URL]
Postby dursleyman » 16 Jan 2015 11:09
My car had a separate thick felt layer under the carpets, maybe up to 10mm thick. Perfect to collect and hold any water that gets in. Its not going back!
1981 TR7 Sprint DHC
fastman
Postby fastman » 16 Jan 2015 11:25
I used a similar product to dynamat produced in Canada. Over top of the foil based sound deadener, I had placed a closed cell foam pad sold by the same company. It is similar to the thick foam underlay found on the rear bulkhead. The company name is B-Quiet. I am very pleased with the results, and this product might be what you're after. There must be a similar product in the UK.
TR7 FHC
DNK
Postby DNK » 16 Jan 2015 12:23
This??
http://b-quiet.com/products-3/b-quiet-vcomp/
Don
Stick a Wedge In It
80 TR7 V8 Kick in the pants
supercass
Postby supercass » 17 Jan 2015 12:06
Steve, yours looks like an after market kit so the felt was probably added at the time the carpet was replaced. The factory sound deadening should still be present underneath. The original carpet had a foam backing. supercass
fastman
Postby fastman » 17 Jan 2015 12:46
That's it Don. It only went on the floor. I re-used the rear bulkhead stuff over the foil backed rubber.
Moderators, sorry about the huge file. I'm a struggling luddite.
TR7 FHC
Users browsing this forum: No registered users and 331 guests
