If you rely on the tyre-in-a-can route in the UK, make sure you have AA / RAC membership with recovery.
Our MX5 has this and both the AA and Mazda dealership recommend against its use even if you're only a couple of miles away from home........ basically there's low to no confidence that it'll work properly on the move.
There is a spare wheel shaped recess in the boot floor....... for a spare wheel. It adds about 5% of not very useful boot space. Great fun to drive though if I had the chance at the weekend.
