Floor
DNK
Floor
Postby DNK » 10 Apr 2014 12:20
Anybody have a shot of the floor pan under the seat with the carpet remove??
A nice clean shot??
Don
Stick a Wedge In It
80 TR7 V8 Kick in the pants
nick
Postby nick » 10 Apr 2014 16:34
Check Beans blog.
nick
'79 TR7 DHC
'76 TR7 FHC
DNK
Postby DNK » 10 Apr 2014 18:44
Nick he's got about a 1000 pages in that thing.
Can you narrow it down a bit [:I]
Don
Stick a Wedge In It
trekcarbonboy
Postby trekcarbonboy » 10 Apr 2014 19:03
That's funny Don. [:D]
Just click the "interior" tab on the right of his blog and there's a couple pics right away.
Craig '75 2.0 FHC
DNK
Postby DNK » 10 Apr 2014 19:29
Do the seats sit on this???
Don
Stick a Wedge In It
trekcarbonboy
Postby trekcarbonboy » 10 Apr 2014 19:40
Yes they mount to the 4 bolt holes in the pic.
Craig '75 2.0 FHC
Postby Beans » 10 Apr 2014 19:41
You learn every day [:p]
DNK
Postby DNK » 10 Apr 2014 20:12
Is the DHC the same?
Don
Stick a Wedge In It
sonscar
Postby sonscar » 11 Apr 2014 07:02
Yes the drophead is the same,Check the mounts on the transmission tunnel as I found that the rearmost was cracked around the reinforcing plate,stangely not due to rust as the leaking engine/gearbox has kept this area rust free.Steve..
DNK
Postby DNK » 11 Apr 2014 11:47
Even though this part is not about the floor , it really is as this is what I was heading to next
I j=-have read the ROM about removing the seats.
Sounds fairly rudimentary. There are only 4 bolts that hold the seats.
I take it that there are "cagenuts" welded to the body that the bolts screw into.
I suppose that I should put it in the air and spray some penetration oil on to the threads then
Don
Stick a Wedge In It
seven
Postby seven » 11 Apr 2014 11:59
Yes you can do that, I use copper slip whenever replacing the bolts back into there rightful place [:)]
Triumph TR7 DHC
Triumph 2.5 Estate
Bentley Turbo R RL
Mercedes 320SLK
Jaguar X-Type Estate
Kawasaki GPZ
DNK
Postby DNK » 11 Apr 2014 12:22
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by seven</i>
Believe me, that is the plan
Don
Stick a Wedge In It
DNK
Postby DNK » 11 Apr 2014 12:30
It just hit me.
Major question the bolts on the raised area, are they longer and the cagednuts are on the underside ,or are they under the channel??
Don
Stick a Wedge In It
Postby Hasbeen » 11 Apr 2014 14:12
There are captive nuts in the channels. In fact I think you can see them in the picture, & one looks to be out of place to some extent.
The system works well here, where I have had no trouble with rusty bolts. I have found 2 of my 7 had longer than suitable bolts replacing the original. 2 of them were so long they had been bent by contact with the road, or obstacle, & had to be cut off to get them out.
DNK
Postby DNK » 11 Apr 2014 14:16
Thank you for that
Don
Stick a Wedge In It
Users browsing this forum: No registered users and 262 guests
