MGF Wheels and 6j
MGF Wheels and 6j
Postby UKPhilTR7 » 02 Apr 2014 05:24
Lounge at some mgf wheels and came across "6j". Not sure what this means as I thought the 14 to 16 inch was the main bit. Can anyone throw some light on this and if they will be ok for our cars.
bonnietiler
Postby bonnietiler » 02 Apr 2014 06:25
It means that it is a 6" wide rim with a "J" type Tyre/rim contour (most common)
There are also J, JJ, K, JK, B, P and D : Tyre bead profiles / rim contour designations.
Some 4x4 use JJ, old Jaguars use K and some older Volkies use B fr'instance.
Bonnietiler
Postby dursleyman » 02 Apr 2014 08:00
Don't you just love the fact that almost all cars still use imperial measurements for wheel and tyre sizes. I can think of a couple of cars that tried metric sizes like some models of the Metro and Montego, and I think some run-flats, but everything else is good old imperial.
1980 TR7 Sprint DHC
bonnietiler
Postby bonnietiler » 02 Apr 2014 08:48
It's even better really cos we use a combination of the 2 systems
195/60/16 f'rinstance
195mm + 16inches...used all over the world?
Users browsing this forum: No registered users and 369 guests
