I have a TR7V8 which i'm really pleased with, I have had to use it throughout the Winter as a commuter, always starts and stops (thanks to the MGRV8 genuine Brake pads/princess calipers) The tyres are fine (damned with faint praise of course) In that they are one of very few tyres actually available for the 13" minilite currently fitted, I have trawled the search engine but found some conflicting answers. Clearly, the most economical method is MGF wheels either 15 or 16 inch. I sort of lean to 16" in the event that I want to go for larger discs in the future should I breath on the motor at a future date?
Could anybody advise me on fitment of either size with tyre size used and the need if any for bodywork mods due to the increased dimensions. Are they a direct fit, do I need to modify hubs in any way are the wheelnut dimensions the same?Will this impact on speedo readings? I am using Power assisted steering so doubt that the feel and weight will be effected unduly
