Wheel balancer
Postby Hasbeen » 31 Dec 2013 23:36
After a fair fight to get the gen set up & running, [shipped dry & required a fair bit of mucking to get reliable fuel delivery], I have given it a few hours on light load to settle in.
Starting the 4KVA motor on the balancer is up there near it's capacity, so thought it worth the effort.
Shock horror, the balancer doesn't go. Well it didn't, I wonder if this is why I got it pretty cheap? The car wheel drive wheel would jump a little, when switched on, but not spin up.
After some disassembly, we found one phase wire was unplugged. With that plugged in, the thing spun up as expected.
I don't think any lower powered generator would have handled the start up load, & I'm not sure it could spin up a large truck wheel, but then I don't have one of those anyway. Still have to give it a good check out before using, but it is getting close now.
With the gen set I am looking at now using the converted greenhouse as the workshop. It was too expensive to run power down to it, for the little I do today, but the gen set changes all that. Time will tell.
Postby Cobber » 01 Jan 2014 02:12
I warned you that you'll end up as bad as me! [:D]
All this talk of converting the greenhouse into a workshop is a fair indication that you're on your way! [:D]
'98 MG-F, 69'Ford F250.
Postby Hasbeen » 13 Jan 2014 00:08
Yahoo, it all works.
I haven't tried it on the 7 yet, but I hooked everything up today, & balanced one back wheel on the front drive Ford/Mercury Capri. This was just a test run, & it went well.
Not great actually, they want a bit of reflective white tape on the tyre for the thing to read. It didn't do too well with my chalk mark on the tyre, but got going much better, once I used a bit of masking tape on the tyre, to chalk up.
I will now order those new tyres for the front of the 7, knowing I can get it steering smoothly.
Wonder where I can get reflective white tape?
Postby Cobber » 13 Jan 2014 00:24
I have a quantity courtesy of a large national railway freight company, it needs to be cut to size.
PM me your postal details and I'll send you some.
Postby Hasbeen » 13 Jan 2014 01:01
Thanks Cobber. PM sent.
Users browsing this forum: No registered users and 44 guests
