Steel wheel sizes
nick
Steel wheel sizes
Postby nick » 09 Oct 2013 21:21
I have a mixed bag of steel wheels from two cars. RKC1513 and RKC0187. Anyone know which wheels were used in which years and why they changed? The offsets are different and the front face on the RKC 1513 is deeper dished.
nick
'79 TR7 DHC
'76 TR7 FHC
nick
Postby nick » 12 Oct 2013 18:24
Come on. Someone out there knows the history behind these various wheel offsets. Where are all the historians?
nick
'79 TR7 DHC
'76 TR7 FHC
whitenviro
Postby whitenviro » 12 Oct 2013 21:29
Nick:
All I know is that my 1980 DHC had the original RKC 1513 wheels on them until this summer. I don't know what the others are from.
[/img]
Postby Beans » 12 Oct 2013 21:38
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
... Where are all the historians? ...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Busy with other wheels [:p]
Postby Cobber » 13 Oct 2013 01:32
<font size="2"><font face="Comic Sans MS">The best use for steel wheels, is bolted to the wall to hang the garden hose on
</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
Postby busheytrader » 13 Oct 2013 06:23
As far as I knew there was only one steel wheel used through 7 production. The wheel trims changed through the ages.
There's a couple of threads out on the net about both part no.s. My old steelies have RKC1513 on them. I wouldn't be suprised if the others came off another Triumph but I couldn't find anything listed.
Postby Beans » 13 Oct 2013 07:17
From 1979 onwards they are listed in the catalogue as part number 151550 ...
But I took a set marked RKC0187 from a DHC and a set makred RKC1513 from another DHC.
Both were Solihull built Californian spec DHC's, and both were fitted with the original wheel trims for these cars.
So I presume (dangerous with BL I know [:p]) that their overall dimensions are the same.
Although they look slightly different if you watch carefully
Postby TR Tony » 13 Oct 2013 07:34
Read this:
http://www.auskellian.com/paul/links_fi ... wheels.htm
Actually about using TR7 steel wheels on the Spitfire (Triumph Spitfire that is, not Supermarine [:D]), but explains quite clearly the differences between the two types of wheel.
Why & when did they change? Sorry, can't help with that.
nick
Postby nick » 16 Oct 2013 15:15
Read this:
As that article states, the two designs have different offsets. Probably something to keep in mind when purchasing used ones to use with ones you already have.
nick
'79 TR7 DHC
'76 TR7 FHC
Postby silverseven » 17 Oct 2013 01:43
if I'm not mistaken , the spitfire rims are 1 inch thinner than the TR7 rims .... so if so , I understand their desire to run "our" larger wheels.
IMHO, the wheels do look nice with the spit cap btw ....
Users browsing this forum: Google [Bot] and 274 guests
