New Wheels!
trekcarbonboy
New Wheels!
Postby trekcarbonboy » 20 Jun 2013 02:29
I finally had the chance to mount my new wheels, and I am quite pleased with the result. [:D]
205/50/15 Dunlop Direzza's mounted on 15x7 Rota "RB" Wheels, Gunmetal Grey.
I love the looks and the handling is so much better. The car is much quieter and the "55mph shake" is GONE! [:D] I will definitely be swapping the old wheels during winter storage to avoid flat spots.
The only negative is that with the extra width of the tires I am now able to notice that the rear axle sticks out the right side 3/4 of an inch further than the left. Any thoughts on how to fix this?
Here's a few before/after pics.
Craig '75 2.0 FHC
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 02:33
Oops, made the pics a bit small.
Craig '75 2.0 FHC
darrellw
Postby darrellw » 20 Jun 2013 03:06
Looks great!
Not sure what could make the axle off-center, any previous damage where the links mount? Or previous fender damage?
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 03:17
Not that I know of Darrell. I'm 2nd owner and Uncle was 1st. Although the 5spd rear did come from another car, so that's an unknown.
Craig '75 2.0 FHC
Postby Beans » 20 Jun 2013 06:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by trekcarbonboy</i>
... The only negative is that with the extra width of the tires I am now able to notice that the rear axle sticks out the right side 3/4 of an inch further than the left. Any thoughts on how to fix this?
That is pretty normal, all TR7 I have had (or broke for spares) so far had the same problem.
Only way to fix it is by making the rear suspension adjusable or by moving mounting brackets on the axle or body ...
b.t.w. the new wheels look quite good [8D]
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 10:25
Well that's a relief to know Beans. Thanks.
Resized
Craig '75 2.0 FHC
Benzo
Postby Benzo » 20 Jun 2013 11:12
They look great craig, if your going for looks, id have the car lowered more :)
Currently back to Basics with my BMW V8 Engined Build.
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 12:08
Benzo, I did install 1" lower springs which achieved absolutely zero drop from original spec. In fact the front sits a tad higher. [V]
It's ok for now as I intend to lower the front by installing a V8! [:D]
Drove the car to work this morning and it has been absolutely transformed! The handling is great but the most significant improvement is the noise reduction. Before with my old multiple-flat-spot-tires the car rattled and shook like I was on cobblestones! Now it's nice and smooth and quiet. No dash rattle, no door rattle, and I went straight up to 85mph without so much as a twitch from the steering wheel. [:D]
Come December I will be swapping the old wheels back on for the winter lay up. Although I do take it out if the weather is nice so I'll just have to deal with the rattling till spring.
VERY PLEASED!![:D][:D]
Craig '75 2.0 FHC
whitenviro
Postby whitenviro » 20 Jun 2013 12:35
Very nice! So how much of the better handling is from new tires vs the 15" wheel? I've always wondered why the larger diameter wheels help, other than let you buy "real" tires!
[/img]
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 13:01
I'd say the fact that the new rims are 1.5 inches wider makes a bigger difference than the diameter. Much bigger contact area with the ground. The larger diameter rim and lower sidewall of the tire will certainly allow less lateral deflection, but I doubt that makes much difference with my driving. And for sure it's easier to get a quality tire at that size.
Craig '75 2.0 FHC
Postby FI Spyder » 20 Jun 2013 13:33
It might be my used to seeing 13" tires but 15" seem a bit large. It would be interesting to see a side by side comparison of 13", 14" and 15" wheels using the same car.
Smooth ride has nothing to do with big tires but with the fact that you have new (good) tires. My 13" Kumho's are silky smooth. I run 30 to 32 psi so tires tend not to get a flat spot as if I was using lower pressures (I think).
While the first few winters where spent up on jack stands for various
projects the last few it's spent on the floor with no side effects.
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 13:43
Indeed!
Craig '75 2.0 FHC
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 16:57
Bonus! The speedo is now correct. It was of by 5 ever since I installed the 5spd.
Craig '75 2.0 FHC
nick
Postby nick » 20 Jun 2013 17:04
With such a large contact patch how much force is it taking to move the steering wheel when the car is stopped? No power steering I assume?
nick
'79 TR7 DHC
'76 TR7 FHC
trekcarbonboy
Postby trekcarbonboy » 20 Jun 2013 17:48
Haven't had to yet, but I never thought it was that big a deal before. I do also have the roller bearings installed. I'm guessing with my big arms I'll not even notice. [:o)]
Craig '75 2.0 FHC
Users browsing this forum: No registered users and 358 guests
