I suspect a leak from the front seal of the 5 speed box in my TR8. It's got quite bad so I need to sort it.
Apart from the obvious matter of removing the box (this will be done with the help of a garage with a lift etc), are there any things to watch out for when changing the seal? I am assuming I need to remove the front cover to get at the seal. I will be changing the clutch while the box is out, and probably the pivot arm.
Any advice from those who have tacked this before is very welcome [:)]
