I was unhappy with how I hard I had to work at finding 4th gear when shifting from 3rd. The shifter always wanted to go into 2nd unless I moved it with some side force. Probably most of you already knew that if the dummy had read the manual he would have known that there is a procedure for setting up the spring tension correctly.
After going through the procedure I am very satisfied at how smoothly the selector moves through all the gears.
nick
'79 TR7
