Was having a chat up at Stoneleigh yesterday with Simon and Ben from Robsport. They now carry a modified heater matrix that gets rid of the seals that seal the feed and return pipes as they enter the matrix. As some may know these seals have not been available for some time and they do leak. Also the pipes that go in and out of the matrix leak, and when you replace them, personaly recomend the stainless steel ones, you idealy need new seal.
As i hope you can see the pipes are part of matrix and all you need to trim down the feed and return pipes, then use heater hose to join it all up.
More details from the lads -
http://www.robsport.co.uk/
1976 Speke FHC Beauty
