Radiator Blanking Boards
Postby John Clancy » 11 Feb 2012 06:42
I thought exactly the same thing Ron.
It's good that Robsport took the trouble to remanufacture something that won't exactly return a fortune, if anything. A good job Mr. Wood kept a set of originals to use as a pattern.
Henk
Postby Henk » 11 Feb 2012 07:44
I made new ones from a sheet of aluminium and no holes but a sleeve for the AC tubes.
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby FI Spyder » 11 Feb 2012 13:53
The N/A FI cars had a single hole for the intake hose to the air filter to pull in cool air from in front of the radiator. You can see the hose (replaced) in the lower right of this picture.
Postby john 215 » 11 Feb 2012 15:34
I have never fitted them to my V8, i like the idea of some cold air being able to get in there.
1976 Speke FHC Beauty
tr7sprint1
Postby tr7sprint1 » 11 Feb 2012 18:39
[quote]<i>Originally posted by tr7sprint1</i>
The US cars didn't have the air housing tube like the cars sold in the UK. It would have been blank just like the left side.
actually no.
The NA spec cars had the same useless (no longer needed) holes as your cars did .....
Both my 78 and 82 had the same cut-out, yet neither had/required the airducts going through them..... though I have always thought it might be a good thing to add, as it would direct cooler outside air into the carbs, instead of simply breathing in the hot air from the engine compartment????
Image Image Image
My purchased new 79 tr7 did not have those holes.
Users browsing this forum: psjmay1960 and 220 guests
