First off has any one looked into adapting the RX-7 front suspension to a TR-7?
This is what I have learned so far; the 1st gen RX-7 front suspension is very similar to the TR-7 including the ball joint. Measuring the taper of the two are the same. Problem with this, other than having hubs with 4 x 100mm is that of the same weak spindle same small brakes. Though I have found a company that makes an adapter to bolt onto the RX-7 strut, which allows the use of the gen II hub.
The gen II has a more robust spindle, way bigger brakes, and the hub is 5 x 114 leading to a larger selection of wheels. The struts will fit with in the same area with the possibility of up-rated springs to 156 lbs and using the TR-7 top hat.
Where the problem lies is in mounting of the spindle to the control arm. The RX-7 uses a straight ball joint that measures 0.709 fitting into the bottom of the spindle and held by a pinch bolt on the center of the ball joint. This ball joint would need a new fabricated control arm to make this work. All measurements are in inches.
The TR-7 ball joint has a taper before the threads that measures 0.642 with the threads at 0.496. The lower part of the taper, measures 0.705, which is very close to the measurement of the RX-7 ball joint. The area of the bottom where the ball joints mount to is 1.013.
What I am thinking here, this is where I ask of the collected wisdom of this forum, if a sleeve was made to fill the area between the RX-7 spindle, using the pinch bolt to secure the sleeve, with the taper locking the sleeve to the TR-7 ball joint. This way the stock TR-7 control arm could be used with out having to re-engineer the front suspension angles.
Thoughts and thank you.
Nov 23 2011 up date. Sleeve to thin at bottom. Looking at Option B.
[url][/url]
Dale
1974 TR6
1977 TR7 FHC
