Okay, this is sick
Spectatohead
Okay, this is sick
Postby Spectatohead » 07 Nov 2011 19:30
http://www.h1v8.com/page/page/1562069.htm
A 2.8 litre V8 that weighs 200 lbs and puts out 400 hp?
Jim Clark
'80 TR8
'97 Maxima 5spd
Postby Beans » 07 Nov 2011 19:48
The only proper thing to do with two bikes, scrap them, weld the engines together and you have a brilliant little V8 [:D]
mb4tim
Postby mb4tim » 07 Nov 2011 20:50
and properly expensive
-Tim
Spectatohead
Postby Spectatohead » 07 Nov 2011 21:50
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mb4tim</i>
Yeah, but don't our cars deserve a $33,000 engine? [:D]
Jim Clark
'80 TR8
'97 Maxima 5spd
trekcarbonboy
Postby trekcarbonboy » 07 Nov 2011 23:25
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Spectatohead</i>
NO! But their owners do![:D]
Craig '75 2.0 FHC
Postby Hasbeen » 08 Nov 2011 00:34
Looks really nice, love how small the cylinder block is.
This is what Daimler did, when they built their V8 Dart/SP250 engine, based on a bike engine. What a pity the car was not a bit prettier.
I'm not sure now if it was a production version, or only a prototype I saw pictures of, running around with 8 Amal [motor bike] carbs attached. Now that would have tested some of us who fancy ourselves as carby tuners.
Interestingly, when Jag inherited the thing with Daimler they had to kill the it off, as it made the XK engines look, & perform, a bit like an old side valve in comparison.
Funny now to think that the Jag XK engines were once considered so exotic that only specialists even touched them.
Marko
Postby Marko » 08 Nov 2011 10:37
Radical does one too.
http://www.radicalperformanceengines.com/engines/
3.2L 88kg of engine = 500hp.
If a regular car had X hours of engineering time invested in its design.
Motorcycles have atleast 10X hours if not more.
If you look at an motorcycle engine block or any other components you will see that everything is as thin as it can be, there 's no material where it shoudnt be. Everything is made to minimum weight and volume possible. Not to mention materials used.
Postby FI Spyder » 08 Nov 2011 15:18
The local Chemainus Caterham manufacturer (for Canada) uses the 4 cylinder Suzuki engine (mentioned in Marko's link) in it's cars. His own car is a supercharged one with something like 360 hp. In 2009 he did a speed test at the Cassidy airport and did 109 mph (in reverse). Could have gone faster but the runway was wet.
mb4tim
Postby mb4tim » 08 Nov 2011 16:00
They can stuff a Hayabusa motor into a Smart car... a beast.
-Tim
grndsm
Postby grndsm » 08 Nov 2011 20:01
I do not know why you need to go that exotic.
Modern turbo 4 bangers can easily make 300-800 hp and they are around 250lbs...
Leon
Marko
Postby Marko » 08 Nov 2011 21:41
that engine is N/A , and there's still room for a forced induction device on it [}:)][}:)][}:)][}:)][}:)]
Stock hayabusa's with a turbo produce 500 hp on low boost.
Not to mention, the layout and volume of that engine is much better for vehicles it is intended for.
+ it has some nice toys that come stock with it like dry sump.
not to mention that that engine can continously produce those 500 hp.
modern turbo 4 bangers (are usualy 2 litre) would overheat at 500+ hp at race pace.
Users browsing this forum: Google [Bot] and 357 guests
