I am not very experienced with electrical issues, so I am asking for some opinions / guidance.
I recently had the front bumper off. I put it back on, and now the turn signals don't work. I originally thought it was related to disconnecting and reconnecting the signal lights when I had the bumper off, but now I am thinking that has nothing to do with it (but I am including this bit in case I am missing something).
I removed the emergency flasher switch from the dash, took it apart, cleaned it, and then put it back in. It did not help the turn signals, but now the emergency flashers work (first time they have worked since I have owned the car).
Since the emergency flashers work, I am thinking that there is power to the lights, and that is not the issue.
I removed the fuse box cover, and it looks like the fuses are ok. Do the left and right side turn signals each have their own fuse? If yes, then wouldn’t it be very rare for both sides to quit at the same time (two bad fuses bad at once)? If the emergency flashers are working, would that mean that it is not a fuse issue?
I think this is all pointing to the flasher unit. I have no idea which one it is (or even for sure where it is). Is it one of the four under the cover behind the headlight in engine bay on the driver’s side (USA driver’s side)? Are flasher units standard (can I get them locally), or do I need something special for our wedges?
Rob
