Fuel tank
Postby windy one » 17 Aug 2011 17:07
It is Not mine, i dont know the seller nor do I know anything about this tank, but..........I just seen this on fleabay. [:D]
http://cgi.ebay.com/ebaymotors/Fuel-Tan ... 2eb73a2570
Postby FI Spyder » 17 Aug 2011 17:08
If it's perforated I would just replace it, seeing which is the cheapest way to get it to you counting in shipping (unless you have a local supplier). It'll cost as much as getting some one to weld it for you (depending where you are.) Used ones are probably close to being perforated unless you get lucky. Unless you get a stainless tank I would give it the POR-15 gas tank treatment if it's a long term keeper. FI tanks are a different story as they are different (double hole) and not available where you have to repair or go the single hole internal pump route.
Postby Wayne S » 17 Aug 2011 17:42
Yes I have, new and ready to fit. I've even sealed it with Rustbuster Ethanol Proof Tank Seal. If you are UK based then happy to sell :-)
If your not UK based, the postage will probably be too much - yours for £80! [8D]
Postby andyf » 18 Aug 2011 06:58
Bugger, wish I knew that Wayne. I just forked out for a new one from Fitchetts!
1980 Persian Aqua DHC
Postby Wayne S » 18 Aug 2011 10:45
[V] Sorry Andy
Users browsing this forum: No registered users and 264 guests
