iedkwok - I went to AutoZone today and saw the vacuum unit they sell (MSD) or at least a picture of it. It is a generic replacement piece that if it looks like the picture I think you have some fabrication in front of you to make it attach correctly. Hopefully the movement of the pushrod is correct after all of that. Good Luck!
Zeke - I believe my gas cap (California car) is a complete seal so your setup should work as a test. I'm not sure that it matters much except for emissions. While you are checking your idle and total advance do a quick check of the firing order on the plug wires too just for grins (been there done that). Hang tough!
[IMG]
