Just one upgrade?
DNK
Postby DNK » 25 Mar 2011 12:21
The stereo?
Don
"No More Cars For You"
71 TR6- Perpetual remodel
80 TR7 V8 Kick in the pants
Postby Hasbeen » 25 Mar 2011 12:51
In retrospect, the most important modifications on 3 of my 7/8s has been relaying the headlight power.
tr7sprint1
Postby tr7sprint1 » 25 Mar 2011 12:53
Is their a write up on this modification?
fiveliters
Postby fiveliters » 25 Mar 2011 17:59
Some suggestions...
To add to what Hasbeen said,I changed the headlamps from the original (yellowy) ones to halogen (bright white)ones. Big difference and not noticeable unless you have the lights on[:)]
You could also change/upgrade your shifter bushings to the newer poly ones...big improvement,and not anything someone would see/invisible.
Re-doing the seat suppor/foam (do a search on this site) is supposed to make the seats much more comfy,as most of them have had someone sitting on them for 30+ years with no change. I have not done this yet myself,as I enjoy the current condition of my stock seats.
K&N filter? Wouldn't see it,but it would have to be less restrictive than the stock paper one.
I removed my tail lights and stripped the remainder of that silvery film inside the metal bulb housings,then re-sprayed with heat-resistant aluminum paint. Lights look way brighter due to being far more reflective,and you don't have to change the wattage on the bulbs themselves.
Run weatherstriping down the vent window channel to reduce wind noise and water coming in. Only time you'll see/notice it is when the door is open.
Hope this helps!
Postby busheytrader » 25 Mar 2011 21:33
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Steve @ SandS</i>
As for the question the one thing I would change on a TR7 would be the brakes.Let's be honest the std ones are crap [:D]
Steve @ S&S Preparations
Agree 100%, smoking brake pads, boiling brake fluid and locking up the front all too easily in the wet. Been there, done it but not all at the same time.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Postby FI Spyder » 26 Mar 2011 02:19
Again I agree with Hasbeen. I've locked up all four wheels in the rain and in the dry, I also locked up only the back wheels (it was around a curve and only the back stepped out a bit). They don't have the "depth" of the Toyota or the Acura (which is four wheel discs) but they aren't that far off. Haven't panic stopped the Toyota but I have the Acura when I hit a deer (no damage to deer (ultimately) or the car but like the TR7 you can't easily lock the brakes. Don't have occasion to use them repeatedly here so can't say how they react under constant use say like on the race track.
HowardB
Postby HowardB » 26 Mar 2011 14:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bottomtop</i>
I would agree convex mirrors would be a very worth upgrade - but I just can't seem to find convex glass to fit the original mirrors.
Not sure if these fit the original frames, but this is what I fitted "
Supplier of mirrors was Tex Automotive tel +44 (0)1993 893 500 http://www.texautomotive.com Part nos M68890E & 891E"
Jolyon39
Postby Jolyon39 » 27 Mar 2011 11:50
I have to agree with Headlights. Original TR7 headlights are now considered pathetic compared to the modern vehicles we often drive.
Most people on the road at night drive around you with confidence because they can see better with their modern headlights. Upgrading your TR7 to more modern headlights makes it possible for you to drive in the traffic stream with confidence. Finally you can drive at the speeds and following distances of the modern cars around you because you can now see well like them. This upgrade is simple and a real safety bonus.
Many things like rubber components in the suspension are really maintenance but I really appreciated my more up to date headlights. Yes relay them as well!
Electronic ignition is a pretty good thing too!
Jolyon
