The best spray on truck liner is Line-X. It is sprayed on hot and can give a smoother or more textured surface. It is available around the world. It is only sprayed on by a dealer as it requires specialized commercial equipment. The cost would probably be about $600 or so.
It was the only product that passed the US DOD test where they sprayed it on a mobile home and exploded a bomb beside it, it was the only trailer to survive. It was featured on the TV show Trucks a few years back when Stacey David was hosting it.
It can be coloured to match your paint. You would effectively have to present them with a body shell as you don't want to get it on anything else. It will not come off....even if you try to explode it off.[:0]
http://www.line-x.com/
I was thinking of doing a Spitfire a few years back. I saw it at a home show where it was sprayed on the under side if a utility trailer. Not cheap but the best you can get. I would imagine the soundproofing would be pretty good too.
