help
Posted: 07 Apr 2008 19:38
<font color="purple"><b>What is the best way to set the points and timing?
I took the tr out of the garage for the first time for about 3 months today
Started first time (has been on a battery conditioner)
Ticked over great reversed out the garage (Bang bang it started to back fire)
Not just a wee bit it was loud bring up the revs slow it is fine to a point ( slight hesitation)
You can’t drive it no power.
I am guessing it is plugs, points, timing etc
Took of the distributor cap to look at the points could hardly see them for the weights
Sitting over them
Question: is there an easy way to set the points and timing
I tried to do static timing with a test lamp
I.E
1. one side on the coil same side that the distributor goes on and putting other side to earth
2. turning on ignition and moving distributor until light comes on
But it did not work (must be doing something wrong)
Help appreciated
I am going to put it in to a guy to get the full engine set up
Timing, Carbs etc
But I have to drive it to him first..
“TAâ€</b></font id="purple">
Sitting over them
I.E
Help appreciated
Timing, Carbs etc
