BRAKES WORKING FINALLY!!!
mnypitTR8
Postby mnypitTR8 » 28 Jan 2008 18:29
OK now we have brakes. Replaced both rear cylinders, all the brake lines, rebuilt the front calipers, replaced the prop valve, and rebuilt a master cylinder that Ted dropped off. So now we have brakes.
I tinkered a little more on the engine, replaced the cap and rotor and it is running smoother now. I am working out some of the electrical now. Funny, the headlights work fine, but no other lights work.
John Peacock
"like many other great ideas this too started with 2 guys in a bar"
80 TR7, Brooklands Green, Maybe on the road soon
98 Z28 over 500rwhp
Postby bmcecosse » 28 Jan 2008 20:45
Well done - and if the headlights are fine the rest will be easy!
mnypitTR8
Postby mnypitTR8 » 28 Jan 2008 21:14
Yeah, I think so too. It sat a long time, so I am guessing grounds and reseat the electrical plugs and it will work. I started preping the wheels for paint, but I dont know if I am going to use them or not.
John Peacock
98 Z28 over 500rwhp
terryjm1
Postby terryjm1 » 29 Jan 2008 00:56
I had the problem of the headlights working and nothing else. It was corroded contacts on the switch.
Terry Merrell
St. Louis, MO
Postby Hasbeen » 29 Jan 2008 00:56
My present car was the same. Headlights Ok, but nothing else.
Did all the usual with the wiring, with some success.
My main problem was getting good contacy between the globe holder,
& the rear light castings.
It was easy enough to get them working, but harder to keep them
working longer than a few weeks, apart from the indicators.
This converted me to the use it, or loose it belief, & I now cycle
through all the lights, every time I start the car, in the shed, &
most times wherever it is.
Since I started doing this, I have very little trouble with any of it.
Postby Rich in Vancouver » 29 Jan 2008 01:40
For the rear lights I ran additional ground wires from the unused spade connectors on the bulb holders to one of the taillight mounting bolts.
Rich
Postby jclay (RIP 2018) » 29 Jan 2008 17:33
Remember, all of the other lights on the car are on two separate fuses. I would check them first. I assume that you have pulled the light bulbs and checked them.
mnypitTR8
Postby mnypitTR8 » 29 Jan 2008 19:27
Honestly, I havent checked anythign yet. I just noticed that one of the tail lights illuminates when the car is running, but nothing else works except the headlights. I only just started checking them out, since I havent been able to drive it anyway. The turn indicators do not work either.
John Peacock
98 Z28 over 500rwhp
Users browsing this forum: No registered users and 241 guests
