QUARTER LIGHTS ON DHC
higgie
Postby higgie » 21 Jan 2008 07:10
COULD ANYONE PLS ADVISE ME HOW TO REMOVE THE QTR LIGHTS.
I HAVE STRIPPED THE DOOR DOWN AND NOTICE ON THE QRT LIGHT A WELDED 90 DEG BRACKET ON THE BACK LEG , WHICH WHEN YOU TRY TO REMOVE VERTICALLY IT FOULS THE UNDERSIDE OF THE DOOR TOP LIP. ANY SUGGESTIONS PLS
HIGGIE
Postby FI Spyder » 21 Jan 2008 19:27
It looks like it won't come out but if you carefully twist it carefully one way and another so as to not chip the paint on the door it will come out. Then you will say "How the h*ll did I do that". Kind of like a Chinese jigsaw puzzle. It goes back in with the same patience and care.
While it's out you can drill out the rivets to remove the glass and rubber from the glass and treat the rubber with rubber restorer/cleaner, clean off any hidden corrosion and repaint the frame with black trim paint. Rerivet that attach points and it's just like new.
Postby Beans » 21 Jan 2008 19:28
You have to remove the side window first. Then drill out the pop-rivet on top and undo two bolts on the inside of the door. You can now remove the division channel.
After that you can take out the quaterlights by pulling them out backwards.
richards
Postby richards » 22 Jan 2008 00:13
i stripped mine complete but they were an arse to do. beans way is probably better.
Get a lifestyle
Get a TR7!
www.ttr7.co.uk
higgie
Postby higgie » 30 Jan 2008 19:31
THANKS BEANS HAVE DONE IT, I'M SURE THAT IT WILL BE JUST A DIFFICULT TO RE FIT THEM.
Users browsing this forum: No registered users and 246 guests
