cylinder head removal
c0rvette7
Postby c0rvette7 » 19 Jan 2008 22:26
AHHHH!!!! I can't get my head off. I have romoved all 12 bolts, but the dang thing is stuck on there. Any advice?
Postby paul w » 20 Jan 2008 00:47
I did this recently.It takes time.Dont loose your temper with it.
Have you managed to remove the studs?The bolts are easy,studs need
plenty of penetration oil.The gasket seal should be broken carefully
with a rubber mallet,tapping all around head.Once it starts to lift
you can use wooden wedges to aid heads removal.Eventually the head
will come away and any studs still in block can be heated and removed
with the aid of stilsons and more penetration oil.This takes patience
about 8 hours of swearing and sore fingers in my case!
See ya. PaulImage
p.s.should be 5 bolts 'n' 5 studs?
Postby Rich in Vancouver » 20 Jan 2008 04:47
In my case it took several hours, big hammers, wedges, and lots of swearing.
Of course the big hammers and wedges destroyed the cylinder head in the process. Fortunately used cylinder heads are cheap!
Good Luck!
Rich
BTW: I have never seen such a poor design! The over-confident Triumph engineers must have been confident that the head would never have to come off for service![:o)]
Postby Beans » 20 Jan 2008 15:16
Pressuming you removed all the studs and bolts (including the ones in front of the head) it should be fairly straightforward to get the head of.
Might need a bit of persuassion with a big screw driver or flat chissel wedged between head and engine to get it free. Make sure you don't damage the mating surface.
Have a good look at Paul w's picture and you'll see where to put it.
Postby bmcecosse » 20 Jan 2008 17:07
If you have all the bolts and studs out - then you have done well! It should come away quite easily now, the usual problem is the bolts being chemically 'welded' to the head - the exhaust manifold if still attached (if not - consider putting it back on) makes a handy 'lever' to wiggle the head free. Just make sure ALL the bolts and studs are out!
Postby jclay (RIP 2018) » 20 Jan 2008 20:11
I have never used this to REMOVE a head, but you could try the cloth rope trick to break the front end loose.
Turn the engine to about one quarter turn before TDC on #1 cylinder. Feed in as much cloth rope through #1 spark plug hole as you can, twisting it as you go. Now, rotate the crankshaft toward TDC. This will compress the rope and push the head off from the inside.
Postby bmcecosse » 22 Jan 2008 21:48
Have you tried just cranking it as it is - camshaft re-connected and ignition disconnected of course - to see if air pressure will get it moving? Decent engine should get about 160 psi in each bore - which adds up to a fair old force on the head!
c0rvette7
Postby c0rvette7 » 30 Jan 2008 22:21
SUCCESS!!! It required a couple of screw drivers... a couple of big hammers, an engine hoist and big long piece of oak to pry with.
and I even managed to leave the studs in. Thanks for the advice... I did do a lot of swearing.
Postby bmcecosse » 31 Jan 2008 14:30
The studs were still in ? You would have been better to remove them first!
Users browsing this forum: No registered users and 243 guests
