Fuel overflow pipes
Posted: 14 Jan 2008 09:27
by simon hubbard
I wonder if you could let me know where the green fuel overflow pipe that comes from the float chamber nearest the bulkhead goes to (left side as it is uk car). It has a clip to attach it somewhere but was not held on anywhere.
Thank you
TRR676R Speke Built 2.0L Tahiti Blue TR7
Posted: 14 Jan 2008 18:48
by colonel bogey
Hi Simon,
On my '7 the pipe is attatched to the coil mounting bracket on the bulkhead.
Hope this helps
Greg.
'76 TR7 FHC Auto Java Green
"Colonel Bogey"
Posted: 15 Jan 2008 08:09
by simon hubbard
Many thanks, I thought that might be the case but then i thought a fuel overflow pipe attaching to an electrical item, surely not! On the other hand...................!!
Posted: 16 Jan 2008 15:42
by UKPhilTR7
<b><font color="green">On mine the pipe was going into a small hole in the frame. But I was not too happy with this so I was thinking of connecting it to the dip stick tube.</b></font id="green">
Posted: 16 Jan 2008 15:48
by simon hubbard
I had to order a new set of HT leads and there was a difference in older and newer models, i believe it is the positioning of the ignition coil, as i found out from the reply the tube on mine attaches to the coil bracket. I looked at your pictures and the badge suggests it is a newer model so maybe that is why you have it leading into the frame, either way it doesnt seem very good.
Posted: 17 Jan 2008 00:18
by UKPhilTR7
<b><font color="green">Yep mine is an older model 1980. True it is not good, never suggested that it was. That is why I am moving it.</b></font id="green">
