Fuel overflow pipes
simon hubbard
Fuel overflow pipes
Postby simon hubbard » 14 Jan 2008 09:27
I wonder if you could let me know where the green fuel overflow pipe that comes from the float chamber nearest the bulkhead goes to (left side as it is uk car). It has a clip to attach it somewhere but was not held on anywhere.
Thank you
colonel bogey
Postby colonel bogey » 14 Jan 2008 18:48
Hi Simon,
On my '7 the pipe is attatched to the coil mounting bracket on the bulkhead.
Hope this helps
Greg.
'76 TR7 FHC Auto Java Green
"Colonel Bogey"
simon hubbard
Postby simon hubbard » 15 Jan 2008 08:09
Many thanks, I thought that might be the case but then i thought a fuel overflow pipe attaching to an electrical item, surely not! On the other hand...................!!
Postby UKPhilTR7 » 16 Jan 2008 15:42
<b><font color="green">On mine the pipe was going into a small hole in the frame. But I was not too happy with this so I was thinking of connecting it to the dip stick tube.</b></font id="green">
simon hubbard
Postby simon hubbard » 16 Jan 2008 15:48
I had to order a new set of HT leads and there was a difference in older and newer models, i believe it is the positioning of the ignition coil, as i found out from the reply the tube on mine attaches to the coil bracket. I looked at your pictures and the badge suggests it is a newer model so maybe that is why you have it leading into the frame, either way it doesnt seem very good.
Postby UKPhilTR7 » 17 Jan 2008 00:18
<b><font color="green">Yep mine is an older model 1980. True it is not good, never suggested that it was. That is why I am moving it.</b></font id="green">
Users browsing this forum: No registered users and 237 guests
