plumbing injection cooling !!!!!!
birminghamtr7
Postby birminghamtr7 » 02 Jan 2008 17:06
here i am confused again and lack of good detail in manuals ( poor memory ) to be fair i did remove some 3 - 4 years ago.
ok so engine is in car and as you do, i am offering bits and pieces up deciding what to paint etc, and i am looking at the cooling in particular, 2 parallel pipes on a bracket that also blocks off the not required fuel pump hole. The right hand as i look from the side is straight forward 1 pipe to pump housing 1 to fuel injection manifold under thermostat.
to the left it looks as though the 2 other pipe are the 2 pipes to the heater radiator, that leaves me, then with the water outlet from the head at the rear which would normally have that tight u bent pipe to the heater radiator on carbed version.
question is what or where does the rear head outlet connect !! any pictures wouldn't half help. On all of the pictures i have, the fresh air duct obstructs the area i'm interested in. my pipes loosely offered up below
mb4tim
Postby mb4tim » 02 Jan 2008 18:34
I don't know if these will help - http://www.tgnagy.com/tr7/fi.cfm
I can try to take more if you need.
-Tim
Postby Beans » 02 Jan 2008 19:25
Injection engines didn't have a coolant connection at the back of the cylinder head.
birminghamtr7
Postby birminghamtr7 » 02 Jan 2008 20:31
ah that might figure, i have stripped a few engines over the last couple of years and never noticed, better get searching through parts boxes for correct end cap or was it blanked off, if you have a close up of that area that would be super. It terrible when you take things apart and you think to yourself ill remember that and guess what you dont.
Postby Beans » 02 Jan 2008 21:17
Sorry forgot, just returned from a friend were most of my parts are stored. Have to go over there tomorrow to return some tools, so will take a picture of the US/PI end plate (if I don't forget [:I])
Postby Beans » 02 Jan 2008 21:25
B.t.w. the end plate is the same for all cars. Only on the US/PI cars the hole were the coolant hose connects is left blank.
Postby FI Spyder » 03 Jan 2008 02:47
Not sure what you're asking for here. Honest, I am not hung over. Here are two pictures one before painting engine bay with everything out and one after painting with water tubes connected. Hope this helps.
birminghamtr7
Postby birminghamtr7 » 03 Jan 2008 08:00
great pictures spyder they will be really usfull could you email them as well that would be really good, But a big thanks beans just gone to box of bits straight in front of me rear end plate as you suggected looks the same as standard apart from casting not machined through i must have just picked up shineest without thinking. here are picture of part for reference for any one. again thanks for all your help.
as you can see looks the same as standard, except for pipe not pressed in.
however when you look at the rear you can see that cast is clearly blanked off.
Postby Beans » 03 Jan 2008 20:15
Glad you found out the difference yourself, because I forgot to take a picture of it [:I]
Managed to create another cooling "problem" though ...
More info on my weblog; http://tr7beans.blogspot.com/2008/01/ruined-water-pump.html
birminghamtr7
Postby birminghamtr7 » 04 Jan 2008 08:24
damn that looks painful hope engine didnt overheat.
Rblackadar
Postby Rblackadar » 04 Jan 2008 16:31
[:0][:0][:0][:0][B)]
Users browsing this forum: No registered users and 263 guests
