<b><font color="green">Not so long ago, I brought a flashing LED from Frost, to give the impression that I have a car alarm. I was going to fit it in the middle of the switch panel so that it is nice and visible. My car has a four switches in the panel, two either side with a spare slot in the middle. This LED comes with a 5 meter cable, so should be enough to reach the battery.
With this in mind, I was wondering if anyone had done anything like this and how easy it will be to trail the cable from the LED in the dash to the battery. Are there any other cables that you can recommend that I follow? Fitting the LED itself should be easy enough as there is already a hole there where it looks like the last owner had something like this.</b></font id="green">
