Fuel Tank capacity
striker308
Fuel Tank capacity
Postby striker308 » 09 Dec 2007 02:24
I thought my 1976 (Californina) TR7 had a fuel capacity like 14.6 gallons. My TR7 wouldn't start the other day, added 4 gallons to it via a gas can and it started right up. I immediately drove to the gas station and it would only take 5 more gallons till the pump shut off.
I'm confused??? Is my tank smaller? Is it possible to only have around a 10 gallon tank?
Karl
1976 TR7
1982 VW Scirocco
tr7jim
Postby tr7jim » 09 Dec 2007 09:57
Karl,
Looking the handbook it is 12 Gallons imperial and 14.2 Gallons US.
Is there a difference over here 8 pints equal a Gallon in england.
On a bad note your tank isn't been suck in so the capacity is by result getting less.
Jim
Postby Chris Turner » 09 Dec 2007 12:28
Jim a US gallon is 6.75 pints, in the 60s our liquid ice cream came in 1 US gallon cans.
www.triumphtr.co.uk
SJW 539S TR7 sprint
1980 TR7 Premium.
striker308
Postby striker308 » 09 Dec 2007 14:38
Tr7jim,
Sorry, what do you mean by ;"On a bad note your tank isn't been suck in so the capacity is by result getting less". Are you suggesting that I might have crud in the tank?
Karl
Karl
1976 TR7
1982 VW Scirocco
Postby jclay (RIP 2018) » 09 Dec 2007 14:45
I, too, thought I had a 14 gal tank, but on reading my original manual last night, found out that my 1980 has a 16 gal tank.
Postby Rich in Vancouver » 09 Dec 2007 18:04
I understand that tank capacity can be limited by how deep the filler neck protrudes into the tank.
Is that correct?
tr7jim
Postby tr7jim » 09 Dec 2007 19:43
Karl.
If your tank is been sucked in so in effect the tank is been drawn in, on its self. E.g. the fuel is been drawn out but no air been allowed to take up the space of the used fuel.
Hope you understand and should be a easy check by looking under your car at the fuel tank.
Jim
striker308
Postby striker308 » 09 Dec 2007 20:13
Tr7jim, yes that makes sense now. I'm just concerned that I might have something in the tank taking up the space. Isn't there a product you can pour in a tank to seal it? Is it possible my tank was repaired at some point.
Thanks,
Karl
1976 TR7
1982 VW Scirocco
Postby jclay (RIP 2018) » 10 Dec 2007 00:08
[url="http://www.gastankrenu.com/"]Link to Gas Tank Renu USA[/url]
mikehardwick
Postby mikehardwick » 10 Dec 2007 19:44
Bending the thread slightly, has anyone managed to enlarge the tank, or fit a custom larger tank? On a long run, 12 Imp. gallons doesn't go very far with a V8[:(] - I can see space being tight when you've allowed for axle travel, but when my existing (original) tank loses interest in further toil I'd like a gallon or two extra in the replpacement if poss.
Mike
Postby Hasbeen » 10 Dec 2007 22:37
I have a complete record of the 140 times I have filled my 7s tank,
in approaching 6 years of use.
On one occasion, when the warning light was on for some miles, it
took 36 liters,[just over 8 gallons] to have it full, to the top of
the filler neck.
On only 3 other occasions it took 30 liters.
I believe that Rich is correct. Its the position of the filler neck
& the breather, which traps a large volume of air, in the top of the
tank, making it impossable to fill completely.
The tank in our 8 is a 7 tank, modified to suit the fuel injection
pick up. It has a modified breather system, allowing it to be
filled, properly. I have got 50 liters, [11.3 imperial gallons] in
to it on a number of occasions.
Postby Beans » 11 Dec 2007 08:44
I managed to put around 60 liters in the tank of my TR7 Sprint on several occasions ...
Users browsing this forum: No registered users and 250 guests
